Hello
i come to you today desperate this is basically my last hope!
I’ll get straight to the porblem.
It all started yesterday when i was copying some files to my external HDD (WDBKHX500ABK-01 500GB) so there i’m unpplugging it while copying files by mistake replugged it not recognised by pc this is not the problem i noticed it makes some Beep sound every 15 minutes like i’ve seen videos on youtube that’s a sing of a failure but i don’t think so because when i plug it it takes time to show as DRIVER F but not showing any space or anthing so i followed thie tut i found on youtube telling you how to format it via CMD i went there did “diskpart” and then selected my disk HDD i knew it cuz i saw the space. and i did CLEAN it took alot of time…then i did as shown on the vid create partition primary everthing went okay then i went to disk managment i saw it’s unallocated there so i clicked on it and everything worked fine till it asked me to a fromat…basically the format takes for ever. and i doubt it’s formatting too becasue no proggres here’s the intresting part…i’ve noticed when i formatted it using NTFS as the file system i want it doesn’t show any progress… but i said let’s try something different so i set the file system to exFAT it worked! and said fromat completed…i was soo relived but oh when i came to try and copy a file a small file!,Says “The Operation cannot be completed because the disk is dirty run chkdsk…”
and when i click on it properties i got to tools check disk for errors and check the box for both options i press okay it stays there for a min then simply disappears nothing happened… so this is really my last hope mates please help me!
