WD my passport lost half of my disk 2TB
Does anyone knows the correct numbers( #cyl, #sectors, #what fat, …) of this External disk ?
what are HD Jumper settings ?
what’s the initial  setup of this disks ?
I didn’t change factory settings,  I’d like to compare with the original settings …
If I open the disk I can’t access about 500 GB of pictures, documents…
H E L P  ??
WD my passport 0748 (USB)
model nr [Deleted-privacy]
p/n  WDBY8L0020BBK
2000.36 GB NTFS
testdisk 7.O Wip data recovery says Chs 243197 255 63
disk 2000 GB / 1862 Gib  seems too small !!   << 2265 GB / 2109 Gib
check the harddisk size : hd jumpers settings, bios detection
the following partitions can’t be recovered
fat16 LBA  109466  142  59   245366  23  46  2183225991
fat12           267072  177 53   275428  35  34   134230176
also
analyse cylinder 129080/243196 : 53%
hpfs -ntfs 0 32 33 243197 57 60 3906961408  (in DLGDIAG is different)
check_fat : can’t read fAT boot sector
invalid FAT Boot sector 0 D FAT12          267072  177  53  275428   35   34   134230176
invalid FAT Boot sector 0 D FAT16 LBA  109466  142 59   245366   23  46   2183225991
i’m running now DLGDIAG (but it will run for 16 hours)
current sector…271361411 of 3906963455  (is different from TESTDISK check)
normal chkdsk /F  stops  at about  599000 files … (and keeps hanging)
Seems like you have a corrupted partition or some corrupted files. You may try to recover them using data recovery software.
