During install process my WD Drive Manager kicks off the WD Services but it does only list
- WD Backup Drive Helper
- WD Drive Manager
It is not possible to automatic as well as manual mode to get to the features:
- WD Backup
- WD Backup Snapshot
After a fail install I re-installed on my first MacBook Pro.
After that didn’t word I installed it on a second MacBookPro.
Same result.
Both using compatible OS versions according the WD specs.
So any thoughts?
