Hi!,
I would like to format my WD Passport to ext3 (linux)
Do I will have any problems with my HD? Does it accept ext3 without problems? Or it may support better the NTFS format?
Thanks to all!!!
Hi!,
Thanks to all!!!
Our drives are tested with Windows and Mac formats. You can try formatting it with EXT3. It shouldn’t hurt the drive if it doesn’t work.
