I have a WD My Passport 1 TB hard drive. It fell down from 2 feet above the ground and since then the drive doesn’t spin on connecting to the computer.
The LED light blinks on and off continuously when it’s connected.
Also, the device manager recognizes a WD SES USB device, but doesn’t install the device drivers, not even from the internet.
Hard drives are really sensitive to physical damage, if it’s not recognized, there is not a lot you can do. Try going to the disk management window and see if you can format it from there.
The drive is probably physically damaged and will most like require professional recovery which isn’t cheap. If you want to do that don’t do any more with the drive.
