Ummm alright so I recently purchased the My Book Duo 12TB external HDD and I was (or still am) having some problems when I was/am setting it up today. It says when you plug the drive into your computer setup is supposed to initiate etc… well it didn’t and I ended up just downloading the setup utilities, backup, etc… from the support page and installing it that way… Anyways I have it all working (I think [I had to manually assign a drive letter in “Disk Management” AND format it]) and it says there is only 10.92 TB of space… I purchased a 12TB where has1.08TB gone to???
It’s some math thing. A 1 T drive formatted NTFS shows about 931 G. So mutiply that times 12 and you should get about 11.172 then deduct whatever software came on it and any virtual CD.
Joe
You would think that would be advertised… But okay then…
