Yep, I can only mount one drive on Truecrypt and it will not open for the second My Book drive and both are 3tb. I can mount 2x 1 or 2TB hard drive easy, but not a 3tb one - anyone know why? I thought it was to do with GPT (GUID Partition Table), but that can’t be it, right? - I’m no expert. Is there anything else that would do the job, anyone?
I am not aware if this is related to a signature collision using the TrueCrypt utility. A signature collision can be addressed for a Microsoft Windows 7 system, but some applications may need dedicated proceedings that would be best advised by the application provider.
http://wdc.custhelp.com/app/answers/detail/a_id/6571/
Regards,
Thank you! I’ll try the solution you provided me with a new drive and move existing data in the old to the new.
