Hi
Would anyone know if the lifeguard diagnostics tool does show found errors even if the extended test is aborted, or do you have to let it work until the end?
Thx
Hi
Thx
If you want to see the test results you need the test to finish. WD DLG will not show you the results if the test is canceled.
Thanks Hamlet
It will take some hours to finish, but necessary things are worth waiting for.
