WD Lifebook Essential - case to usb cable
I purchased an WD Lifebook Essential 2TB, but i don’t like the case (animals and dust gets inside) and i want to use the hard drive with my SATA cable.
I removed the power supply chip and plugged in the drive with a SATA cable to the PC, however the drive is not recognized. Kindly refer to the following screenshots:
I appreciate some suggestions on how to make the drive recognizable.
With Regards,
Anthony
I did some research and found out that the drive requires more power to boot.
The Sata to USB cable that i purchased is only sufficient for a 3.5 inch hard.
Is there a way to use the original supply and plugin in the Usb cable part?
Anthony
2.5 inch actually.
No.
You should have purchased a Sata to USB Enclosure instead of an Adaptor
Sata to USB Enclousures come with a AC Power Supply.
