I downloaded Windows 10 Media Creation Tool to my external hard drive and it divided it up into FAT32 and NTFS. The external hard drive used to be found under H: but now it is under F:. I see a Recovery D: when I open up Disk Management. How can I find the folders I had on there? How can I fix this?
Hello, Kimber350
Maybe you should try contacting WD’s Technical Support about this.
http://support.wdc.com/support/case.aspx?lang=en
