WD Elements SE not readable
Drive was working, but running slow. After re-booting PC I cannot find the drive but it is shown in the device manager?
Please refer to the following KBA: Error
The possible causes for such an issue can be an incompatible file system, missing drive letter, disk driver issues, damaged partition issues on the hard drive. In a worst-case, the drive itself is failing.
You can try the below fixes to resolve the issue:
  1. Initialize the drive or drive partition
  2. Change/Assign drive letter
  3. Update Disk drivers
  4. Enable drive in BIOS
