WD Elements Different Model Numbers WDBBKG0040HBK vs WDBWLG0040HBK
I recently purchases a WD Elements 4TB external desktop hardrive,
I notice the model number is WDBBKG0040HBK-AESN
When I look up on WD official website for my hard drive, I notice the model number is different, it is WDBWLG0040HBK-NESN.
May I know if the hard drive I purchases is a legit WD hard drive and what is the difference between the 2 model numbers since they are both wd elements external desktop 4tb.
I have also notice that the power adapter that I was provided is a little different from previous WD external drive i have purchased. The power adapter pins are rotated, so when i plug it into a powerpoint, it goes in sideways, so the wire extends out from either the right or left side.
My older power adapter pins are rotated normally so that the wire drop downwards/below from the adapter when plug into a power adapter.
Is this new adapter correctly positioned?
Thanks.
Hi ra2havoc,
You should try contacting WD’s Technical Support about this for live assistance
The link below will allow you to call support
Create a Support Case
Create a support case with our world-class service and support team.
