# WD Element Transfer Rate
**URL:** <https://forums.sandisk.com/t/wd-element-transfer-rate/356243>\
**Category:** External SSD for Windows\
**Created:** [August 12, 2014, 10:48pm UTC](https://forums.sandisk.com/t/wd-element-transfer-rate/356243 "2014-08-12T22:48:43Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Author:** ![blu17](https://avatars.discourse-cdn.com/v4/letter/b/b487fb/32.png) [@blu17](https://forums.sandisk.com/u/blu17)\
**Post date:** [August 12, 2014, 10:48pm UTC](https://forums.sandisk.com/t/wd-element-transfer-rate/356243/1 "2014-08-12T22:48:43Z")
</div>
I recently bought a WD 3 TB Element. MyOS is Widows 7, 3.0 USB.
I read another post on this forum that he was getting a rate 120MBs.
I have 20MBs,I called WD tech support and was told 20 is normal.&nbsp;
What am I missing here,do I have a faulty drive?
thanks
R
**Author:** ![Trancer](https://sea2.discourse-cdn.com/sandisk/user_avatar/forums.sandisk.com/trancer/32/36707_2.png) [@Trancer](https://forums.sandisk.com/u/Trancer)\
**Post date:** [August 13, 2014, 12:00am UTC](https://forums.sandisk.com/t/wd-element-transfer-rate/356243/2 "2014-08-13T00:00:38Z")
</div>
What is the exact model of this WD Elements? If it is a USB 2.0 model then 20 MB/s is normal for most systems, while stronger computers will reach around 40 MB/s. If it is USB 3.0, then check your system drivers and the physical port you are using as it should reach around 90 MB/s on most USB 3.0 systems.
Regards,
**Post date:** [August 13, 2014, 12:43am UTC](https://forums.sandisk.com/t/wd-element-transfer-rate/356243/3 "2014-08-13T00:43:14Z")
</div>
Trancer,
It’s a 3.0 Model,
Thanks !
R
**Author:** ![Joe\_S](https://avatars.discourse-cdn.com/v4/letter/j/67e7ee/32.png) [@Joe\_S](https://forums.sandisk.com/u/Joe_S)\
**Post date:** [August 13, 2014, 3:57am UTC](https://forums.sandisk.com/t/wd-element-transfer-rate/356243/4 "2014-08-13T03:57:10Z")
</div>
That is about the right transfer rate for USB 2. Make sure all of your USB drivers are up to date. Sometimes the USB ports on a desktop work better than those on front. Also don’t connect through a hub.
Joe
