WD EasyStore is read only
Just bought a new 4 TB EasyStore because I need a place to store video, but I can’t move anything to it. I have a Mac and I’ve reformatted the drive for Mac, but it won’t let me drag and drop any files into it. It says “deborahwrites” can read and write but no one else can. If I try to change the others to “read and write” it tells me I don’t have permission to do that.
I think something is wrong because it’s not even asking me if I want it to automatically back up anything.
Made sure you format your drive as “Mac OS Extended (Journaled)”.
Check your Mac security setting on the drive. Just right click on the drive and go to “Get info”, under “Sharing & Permissions” double check your setting.
