WD DUO power and white ligh
Just received a new WD 20Tb DUO. Manual says a single press of the power button on the back should turn it off. This has no effect. Only a 4 second press will force a shutdown. Also should the white light on the DUO go off when shutting the PC off? This remains on. Tried WD support with no suggestions. Anybody having a similar issue. TIA
Andy
Hi Fletch007,
I suggest to test the drive with WIN DLG
downloads.wdc.com/windlg/WinDlg_v1_31.zip
