1. My 1 TB drive showed that I had only 13 GB left.
2. I trashed over 200 GB of old back-ups (emptied the trash as well)
3. My drive still says I only have 13GB left.
Any ideas?
Any ideas?
Hello johnedwardlow, welcome to the WD Community. Try running a DLG test, if any problems are found it will try to fix it.
How to test a drive for problems using Data Lifeguard Diagnostics for Windows
Is there anything like this for Mac?
Yes, for Mac’s you can use the Disk Utility.
Thanks jubei40. I have run Disk Utility but it found no issues with the drive.
Some additional information about this drive:
It is not searchable. It is listed as a ‘searchable’ drive in Spotlight but searching for a file on the drive turns up no results for files I know for certain are on the drive.
Not sure if these two things are related although, in my mind, they’re both related as evidence that this drive is a dud.
