Hello!
I’m working in both Windows 7 and macOS High Sierra. Whenever I’m working on something (writing in particular) and mount an USB the WD Discovery pops up and I can keep on writing a couple of sentences without actually writing anything because of said popup.
Is there a way to block the popup by using Terminal on Mac or in the registry in Windows or some other solution?
If not: Is there another way for me to connect the My Cloud device to my computer so that it appears like a regular folder (as it does with WD Discovery) so that I can uninstall WD Discovery?
Thank you all in advance!
