Hello
I am trying to transfer my WD Blue PC SSD 500gb (WDS500G1BOA) to an external caddy, as my MacBook is not recognising it and I want to check whether it is the drive or the internal cables.
However, I have 4 small bits that stick out along the longways edges (photo attached) and it doesn’t fit the caddy due to these. Is it safe to remove them, and if so, how, and will it be possible to reattach if needed later?
Thank you,
Ben
