I just purchased the WD_Black P10 Game Drive and attempted to connect to my PS4 to setup as an external drive. Unfortunately, the device did not display as available. So, next I tried connecting to my PC to check on the HDD, and the drive did not show up under File Explorer, Device Manager, or Disk Management. Not sure what else to do…any suggestions?
If you intend to use it as a “Media” drive on the PS4 for playing Movies, Video, Music, Photo’s etc … it needs to be formatted either FAT32 or exFAT. (recommend exFAT since it supports file sizes over 4GB)
If you intend to use it as “Extended Storage” for PS4 Game and App Installations then you need to format it on the PS4 Console.
From yourPS4 ™, go to [Settings] > [Devices] > [USB Storage Devices]. Select the [USB storage device] and click [ Format as Extended Storage ].
Note: Once the drive is formatted as “Extended Storage” it can only be used on the PS4 Console for Game/App installations and will not be compatible with your PC. (you can however, re-format back to use with PC under Disk Management … this will erase everything on the hard drive)
Lastly, if you wish to use an External Hard drive on the PS4 for Media PlaybackandExtended Storage … then you will need 2 External Hard drives to accomplish it.
I didn’t know that after connecting my WD Black P10 to my PS4 I wouldn’t be able to access the device on my computer. Any suggestions on how to revert it back via format or whatever so I can use this the P10 on my Windows laptop? I looked under Disk Management and I am unable to format it back.
