For the last years I’ve been using WD Backup with great pleasure and easy on the home laptops. After converting to Win10 the support of the SW stopped…
Question now is - whatsoftware is compatible with the WD backup tool so I do not need to recreate and verify backup plans, is the cheapes solution to buy a new network disk and move the old stuff? Basically this decision of WD made me buy the next disk from LACIE, but I would like to have the same functionality as before. is the Acronis SW a solution - is this supplied with new disks, and is it compatible with MyBook White light.
