Hi there
Been using WD Backup for a while as a daily backup on my Win10 machine.
A good couple of months ago, i realized it was not running properly - and even though it would start (i found the windows notification) - it would stop a few mins later with an error saying “target not found” or the like. I could not get it to work, and eventually - uninstalled and reinstalled and setup the backup plan a new. Now - when i start it manually, it just says “preparing backup…” for a while, and then that notice disappears and evidently nothing is happening - as there is nothing new in the folder on the drive. and there is no “last backup” date (see below)
Any idea what is happening? is there a log file somewhere?
@kneidels
If you are using WD Backup and it works then fine but if there are problems I doubt anyone with WD will try to spend time trying to figure out the problem. Like me, they’ll probably tell you to switch to Acronis.
I tried Acronis but didn’t like it. I use Windows File History to backup with or drag and drop for things I definitely want a backup of.
I liked SmartWare but like WD Backup they quit providing support for it.
Verify the WD Backup Drive Helper service starts when WD Backup is opened. Make sure WD Backup is allowed and not blocked by anti-virus software. Ensure the WD drive is connected directly to the computer. Ensure the drive firmware is up to date.
