WD 2TB Elements Desktop External Hard Drive USB 3.0
(as a films storage) - formatted properly (exFAT) - does not work on my TV LG 22MN43,
the window on the TV screen reports: Problem on the USB Device. Please check USB…
although
1/ this device does work on other tested TVs
2/ all four my older 2TB devices work on this TV
Who can advice how to solve this problem? Thanks in advance
You should try to check WD Elements desktop on PC. And run diagnostic test to check the health of drive using Data Lifeguard Diagnostic for Windows tool.
https://support.wdc.com/product.aspx?ID=307&lang=en#WD_downloads
Thanks but done, it works on PC normally, good health reported…problem probably is in too old model of TV LG 22MN43 (cca 6 years) - the loss of compatibility?! Why? I`ll sell it and purchase an older model…M
