I expanded my fuze with another 8gb, but other than that it’s stock. I record a memo and it does not appear. i sync it, i see in on the disk using windows explorer, i detach from usb, it is still not in the voice rec folder (on the fuze screen). after i sync a few times, and if i’m lucky, it’ll show up in the voice rec folder (on the fuze screen).
anyone else having this problem? the voice rec was a major reason i went with this over a nano and it’s not working!
I am. If I remember correctly, from my computer I see them under
g:\recording\voice
Correct, when I immediately finish recording, then go back to
voice->listen to a recording
it is not there. If I sync to the machine I see/play it through windows explorer, but after disconnect it’s still not in
different issue, but possibly related, just to give a little more info:
It also takes a very long time (10 minutes+) immediately after disconnecting (and/or the next boot after disconnecting and powering down) while saying “refreshing library” or something to that effect (sorry, but you know what I’m talking about).
I am having a similar issue. I recorded several voice memos. I verified that they were on the Fuze. Then I used the sync cable in MSC mode (I have a Mac running 10.4.11 Tiger). I mounted the Fuze on the Desktop, added some music and unmounted. The music was there, but when I navigated to my voice recordings, the area said [Empty]. I was seriously bummed. But, the next time I connected the Fuze to my Mac, I navigated to the Record/Voice directory, and…all the files were there! I copied them to my computer, unmounted and…gone again.
Then, as a test, I recorded a voice memo. Checked to make sure it was listed on the Fuze. Then, I connected via the sync cable to the Mac. Once the Fuze appeared on the Desktop – on the Mac it looks like a removable drive – I waited about 30 second, then unmounted it. The file was gone (from the Fuze display). I remounted the Fuze and opened it up in the Finder, and all my files plus the test one were there!
