When creating a voice recording everthing seems fine. I see the amount of time available on the internal memory left. I see the name of the file (bunch of numbers) and when I stop and select save it takes a few seconds and seemingly taking the time to save them. But When I go to the play a voice recording there is only an [empty] display. The info screen show zero voice recordings.
However, they have been made because when I connect it to my pc. They are there in the appropriate folder, I think it is called voice on the internal card.
I shut down and powered on to see if it wanted to refres the index. But it didn’t refresh after powering up. I took out the external card to to force a refresh and that did the trick! This surely shouldn’t be the way…it should be working…Sansafix?
