Does WD Security (or the HDD itself) protect the HDD from viruses trying to infect/delete the files?
Hello qaz_1,
Currently, the WD Security is a hardware base encryption program. You can use this application to lock and unlock your drive in case that you have sensitive information that you don’t want share if someone is using your pc while the drive is connected.
The WD Security app is not designed to protect the drive against viruses.
