Ok, so I finally got “Any Video Converter” and started to convert a few videos into .mp4 so i can place them on my Sansa. The coversion went perfect, and so did the transfer, but when i try and view it on the sansa, it plays at a very high speed. Any suggestions?
You specs may be off… I believe you should be setting the output Frames Per second to 15 Frames Per Seconds…
Hope this helps…
Good luck!!
