I just got a new sansa fuze as a gift and uploaded a movie on to it in multiple pieces since i couldnt just do it whole. It’s the Dark Knight and as people may or may not know it’s long but when i play each piece thats been cut into 10 minutes the screen goes all fuzzy with green and red secs and i can hardly see a thing at all. Is there any way to possibly fix it?
Did you try using Sansa Media Converter to put it all on as one piece. YOu have to use SMC no matter what you do, but If you put it on as a while you may avoid the problems. This will most likly take a long time to do but it may all be worth it. I am going to try to do my copy od TDK tonight as one big file.
