I have a e250r and every video I convert plays out of sync (sound is like 5 seconds ahead of video)
I use the media converter that came with the device.
I have played the files (from the sansa device) with Quicktime on my PC and the video/audio is in sync when played on my PC. But on the e250r, the video/audio does not match up.
Having same problem. Music video is not 10 mins long.
Converted wmv to mov using Sansa Media Converter while device was connected to PC.
Sound and picture are out of synch when played on device.
Converted wmv to mov using Sansa Media Converter and had file saved onto PC
mov works fine on PC
copied file to device
wmv file was 27,796K
mov file is 25,458K
Song is only 3:55 mins long
Is there an upgrade to the firmware for the e250r that will allow my music videos to play in synch?
Is there some other way to fix this problem.
