Anyone know of a decent vent clip mount for the Fuze?
Thanks,
Rick
Thanks,
Rick
I just bought an adjustable cell phone one for my car. Actually fits pefect. The sides adjust out with a push of a button and you slide them in to fit the cell phone… ah Fuze. I use it for my MP3 player (and use it in my cup holder instead). I found it on clearance, but any adjustable vent clip would work.
http://www.amazon.com/Arkon-AIR-VENT-PHONE-MOUNT/dp/B000XDQP5I/ref=sr_1_4?ie=UTF8&s=electronics&qid=1221774200&sr=1-4 says it adjusts with the push of a button. Maybe search for others for prices, this is just one I found. I Just searched for Vent Mount.
