I just got a new ScanDIst USB Drive and am trying to figure it all out.
If I look at it outside of the scandisk software, I can see My Vaults folder.
Then under that is the My Vault folder where it appeas to store the file when I move a file inside the scan disk software… Can we have multipe vaults? How do we access.
My Vault - Protect your personal and sensitive files in a private folder or “vault” on your USB drive - so you can share your USB drive with ease knowing your private files are protected.
I think there is not much use of having redundant folders. You can probably create subfolders under it.
