# V-Mate Suggestions
**URL:** <https://forums.sandisk.com/t/v-mate-suggestions/15627>\
**Category:** Card Readers | Adapters | other products\
**Created:** [January 11, 2008, 12:22am UTC](https://forums.sandisk.com/t/v-mate-suggestions/15627 "2008-01-11T00:22:27Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![untroll](https://avatars.discourse-cdn.com/v4/letter/u/8e7dd6/32.png) [@untroll](https://forums.sandisk.com/u/untroll)\
**Post date:** [January 11, 2008, 12:22am UTC](https://forums.sandisk.com/t/v-mate-suggestions/15627/1 "2008-01-11T00:22:27Z")
</div>
I’m a new user of you V-Mate. The idea of the product is really great… On the other hand, the product is “not ready for sale” because there is some really annoying things.
1- You can’t use the product without installing the latest firmware. The recording quality is poor and the refreshing is not fast enough. After updating the firmware, the product works well.
2- When you’re watching a video, if you press on STOP, you have to restart the video from the beggining. You can’t fast forward rapidly. To avoid this, it should work like a DVD player :
&nbsp; Pressing the “Fast Forward” button
&nbsp; 1 time = 1x fast
&nbsp; 2 times = 2x fast
&nbsp; 3 times = 4x fast
&nbsp; 4 times = 8x fast
&nbsp; 5 times = 16x fast
&nbsp; 6 times = 1x fast
&nbsp; Etc.
&nbsp; Then press “Play/Pause” to play the video at normal speed.
3- When recording in full quality, we lose the TV image but not the sound. This is ridiculous! It should return to the “normal” television image.
4- When using the remote control and by pressing on any buttons, an icon corresponding to the button should appear on the TV to confirm that this button was pressed.
5- Sometimes nothing happens when playing a video . There is a blank screen. You have to press “Stop” and “Play” to retry.
6- There should be an option to clear the menu to go back to the TV without powering down the device.
7- It should have a place where we can see the free space on the flash card and an evaluation of the remaining time according to the selected quality.
I hope you will upgrade the current firmware and add those options to your product.
Thank you.
**Author:** ![blackjenna](https://avatars.discourse-cdn.com/v4/letter/b/8e8cbc/32.png) [@blackjenna](https://forums.sandisk.com/u/blackjenna)\
**Post date:** [June 30, 2008, 11:30pm UTC](https://forums.sandisk.com/t/v-mate-suggestions/15627/2 "2008-06-30T23:30:21Z")
</div>
i had just bought the TakeTV when I seen the v-mate on the web site. i was thinking about getting one myself but then i though about the fact i’ll be needing a dtv converter and if i’m not mistaken both the dtv cnvtr and the v-mate use the same inputs. if there is a way to use both i would like to know, then i’ll buy for sure. btw is there anyway to use usb flash drives as storage. i know they have usb readers for sd cards but are there any that work the other way around -usb to card slot-??
