Utility Software to deal wityh ID tags??
Anyone know of any good utility freeware software for mass editing of id tags etc. I have gobs of old time radio shows that are a real mess when it comes to tags that I need to convert.
Try MP3Tag. Make sure you set it to write the tags in ID3v2.3 ISO 8859-1 format, the preferred format for Sansas.
Thanks, See I have many audiobooks and OLD Time Radio Plays that are variably tagged and I needed something that would do the job en masse, rather than one file at a time. For instance, most don’t even have the ‘genre’ filled in as “audiobook”.  Further many are flat wrong. As in Genre being set as “Mystery”, “Novel”, etc.
@miikerman wrote:
Both MP3Tag and The Godfather will allow you to edit the ID3 tags en masse.  It’s been awhile since I’ve used The Godfather, but if I recall correctly, it also will allow you to retag using variables.
The Godfather? :dizzy_face:
