I will be using 2 2TB My Books, one to store certain data from my computer, and would like to use the other to back up the data from the first one to the second one, on a schedule. Not for Time Machine use. Will the enclosed software be able make that happen or do I need something else?
Unfortunately, you wont be able to do that with the WD Smartware backup software. You might need to get a third party back software.
OK, thanks. WIll check on that then. If anyone else has an idea, please speak up ![]()
