Is there a website to download a user’s manual for the Sansa E280? Thanks in advance.
jfunk,
Thanks for the link to the manual!
No problem. You may want to take a look at the How To videos as well. There are ones covering WMP which may answer your question regarding disconnecting it from there. I use drag & drop in MSC mode myself and use the generic Windows “Safely remove hardware” thing, so I’m not sure if the procedure would be the same in WMP.
The links to them and some other stuff are on the main e200 page, on the right side:
http://www.sandisk.com/Products/Catalog(1166)-SanDisk\_Sansa\_e200\_Series\_MP3\_Players.aspx
