Using a Cruzer Extreme 32GB USB3 drive on a Win7 PC.
Accidentally deleted the .exe file from my USB disk, which meant I couldn’t access the vault. Downloaded it again and ran it, but after I entered my password and clicked on “Next” on the 4 ways to add files splash screen, the app immediately crashed with a Windows message advising it had to be closed down.
Had to delete both vault and .exe, and start again. Thankfully I had put the files in a temp folder on my desktop, so nothing was lost.
Unless I’m missing something, this is a pretty useless app, as it does nothing to actually protect your data? If anyone can view the 2 files on the USB disk, and can choose to delete the .exe., the vault seems to be rendered inaccessible, and the data’s lost.
Surely the app should auto-run when inserted into a PC, and there should be no way to edit either vault or .exe of the SecureAccess files on the key, without inputting the password.
Is it just me?
Thanks
G.W.
