I bought a Fuze so I could use my player with Linux, the operating system I use. It is replacing a Connect, which doesn’t support Linux. Anyway, the Connect came with an AC adaptor for the USB. Can I use that with the Fuze?
Yes, the 30-pin Sansa cable will work fine with either device.
Bob :smileyvery-happy:
I have a connect. I use the connect cord with the fuze all the time. To be honest I couldnt tell you which of my 2 came with which player
