USB Drive Bending
I have SanDisk Ultra USB 3.0
I installed an application on the Flash drive and it quite literally slowly started to melt and bend.
I bent it back to shape with my hand but is there a way i can prevent this from happening again?
Unusually high temperature !, is it hot where you live ?
Try not connecting the drive directly to the pc, use a short USB cable.
