Hi!
Can you connect a USB and Firewire simultaneously to a WD MyBook Studio? The FireWire is connected to the computer while the USB is connected to the router… can you do this?
It is the setting where if I’m not near to do fast transfers (FireWire), I can use the Network (USB) to transfer files…
