And when i try to connect it to my laptop, it’s loading but it’snt recognized by windows 8
Since i’ve got only USB3 ports on my laptop ,i’m wondering if there is a compatibility issue with the Sansa.
I’ve already try to change the USB settings from auto to msc, but it didn’t fix anything.
Actually I can access the Sansa clip + with another laptop running Windows 7 and USB 2.0, but I am really disapointed because I dont understand how a Brand like Sandisk can ignore that USB 3 is now the standard connection.
Apparently, Wlindows 8 is not totally compatible with Sansa manager. I had no problem with Windows 7 with my new Sansa Plus player or my previous Sansa player. I converted to Windows 8 recently, and wished that I hadn’t now.
I did get the new player to work with Windows 8, but it’s much more work than previously.
If your windows 8 is a release that has or will support virtual pc mode, you could try running windows xp mode under virtual pc. I’ve had mixed luck with this on windows 7 professional, couldn’t get my scanner going.
Not sure what you mean by loading but not recognized.
