Software downloaded don;t know where but Vault created and Files dopped in after password created.
Does this thing work in Windows 10?
]How does one acess the vault actually?
Software updated?
Thanks for feedbak.
Or else I just rerfomat this drive and use as a regular stick
Tealeaf
there is a new version of the software out. I would recommend updating to Secure Access 3
http://kb.sandisk.com/app/answers/detail/a_id/2399/
ed_p
3
Hard to update if the OP "Software downloaded don;t know where ".
OP, when you find the downloaded file, you need to move it to the USB drive and execute it.
You don’t need to reformat the drive to use it as a regular stick. Simply deleting a couple SecureAccess folder/files accomplishes that.
Reinstalled V3 and I am on board.
it just did not show up on the Drive first time even though I clearly remember it loading.
Tks Gurus
T
