Is it possible to upload a iPhoto slide show to my Sandisk SDCZ36-002G-A11 and view it on my digital TV? If so would appriciate instructions and suggestions.
Thank you
Thank you
well if you can save the photo show as a file then yes it could be transfered to the drive. that being said the tv probably does not support the file format that iphoto would save it in so the tv probably would not be able to display it. it would probaly be easier to get a dvi to hdmi cable and connect your computer to the tv.
