Upgrade seemed to run ok, but Backup & Retrieve tabs greyed out on restarting. Any ideas?
Fulmer
Fulmer
Make sure to click the external drive on the home tab
after that you will have access to backup and restore
I had the same problem as the O.P. Are you serious? It was that simple?? Thanks, Wizer.
Unfortunately, I had so many problems with this upgrade that I erased the drive, and now it looks as if everything that came pre-loaded on the drive is gone. Is there any way to…ah…restore that?
Thanks again!
of course you can…
download the CD Image
Thank you again!
