I grabbed the update to 2.1.0.11 ran it. Got a message about a missing dll file then it rolle back 1.4… and now I cant set up anything. I know I blew it. I am now downloaded 1.4.1.2 so have it.
Do you I refort and start over?
Any ideas?
Any ideas?
I would like to add that I have downloaded 2.2 and when I run it does not do anything. So, reformat and star over?
I wouldn’t do the update unless you were having problems with the drive. If it ain’t broke don’t fix it. Try turning off your AV make sure your netframework 3.5 and adobe flash are up to date.
Joe
I know that. I was a mistake that I did it. I need to know what to now? reformat and start again, or is there a way to repair it.
Uninstalled old WD software and reinstalled.
