Jlbgreen-
Note that the folder labels are all in capital letters? Your device is in MSC mode. Yes, you have run into TWO happy Microsoft issues.
There is a virtual wall between files transferred in MSC versus MTP modes. From the computer side, you cannot access or see files transferred in the alternate mode. This is different from the familiar “hidden files” issue.
I’d bet that your device has dropped the MTP connection in favor of MSC. If Auto Detect is selected on the device, it will select MSC if the MTP connection is not available or supported.
On the Clip, go to Settings > USB Mode > MTP and plug in.
Open a Windows Explorer window via [Windows key] + E, or My Computer. Where do you see your wee Clip? If it’s listed under other , as a media device, it’s in MTP mode, and it won’t have a drive letter assigned to it. MSC devices will show up under devices with removable storage , as a flash drive, and will be assigned a drive letter. Another hint is that MSC device mode involves all-capital ID for files and the logical drive designator.
Did you just update your firmware or make an operating system change on your PC? If Windows Media Player 11 isn’t installed, go ahead and upgrade to it. WiMP10 or WiMP11 have the requisite drivers for MTP mode. In fact, MTP is a virtual mode that is integrated into the player code, to support secure wma format (DRM).
If WiMP11 is installed, you can go to the Device Manager, uninstall the Clip, and then unplug. I prefer to reboot at this point, learned from years of fighting the Windows Registry, but you can plug in again and watch Windows reacquire the player. You should see the happy Found New Hardware balloon.
Windows is so “happy joy joy”, isn’t it? Perhaps, they should have made the Vista logo look more like a turkey?
Bob :smileyvery-happy:
