With the Sandisk clipped to my belt I often find that bending or other body movement will cause the music to change stations or a mp3 to reatart. Is the a Lock switch that will prevent unwanted changes? Does any one make a Hard case that will neatly fit the player and prevent a buttons from being pushe unintentionaly?
Press and hold Back Button for 2 seconds to enable Key lock, press and hold back button 2 seconds to disable.
EXCELLENT!
Thanks
Does anyone happen to know if the Jam has a lock/unlock feature?
Thanks much!
