This usually means that your computer is confused about what the player can and cannot handle. Which version of Windows Media Player do you have? Also, what firmware version do you have on the Connect?
If this message is being displayed by the Connect, I don’t think it has anything to do with his computer. Mostly likely it’s exactly what it says … the songs were not encoded in a bitrate that the Connect supports. ( OK, it would’ve made more sense if they included “bit” ).
According to the user’s guide, “The Sansa Connect player will support 64-192 Kbps for MP3 and 32-192 Kbps for WMA.” Actually I’m not sure if this is correct as I think I’ve put 256 Kbps songs on my Connect. Hmmm.
