Unpaid Rebate
Hi
Does anyone know how I can get in touch with someone at Sandisk about an unpaid rebate from last June? I have copies of my form and receipt.  I’ve tried several numbers and no one seems to know what’s going on. Here are the two  I’ve called with no result.
(866)568-9228
(866)701-7637
Any help would be greatly appreciated,
Brian
A bunch of SanDisk contact numbers at the link below, although I have no idea which number will be helpful for rebate issues–hopefully, someone at one of the numbers will be able to help/direct you (rebates also could be handled by an outside company). You might want to check the tiny, fine print on your rebate form, if you haven’t had the chance to do so, yet–these sometimes will supply a rebate contact number, if you actually can read the tiny print. :wink:http://www.sandisk.com/sandisk-support/contact-us
I just want to ask if there is 24/7 customer support
If you clicked on the link above, you’d know the answer to that question.
But I for one, am trying to figure what what your question has to do with the subject of this thread (rebates).
