Unit turns off when shaken
I’ve had my 2Gb Clip for a few months and now it turns itself off suddenly if the unit gets shaken, like when I run.
Now what? I thought there was no moving parts?
Thanks for any and all replies!
It is possible that a wire has come loose on the inside. There hacve been reports that one of the wires that connect to the battery can come loose. If you are still under warranty which it sounds like you are Call Sandisk and find out about an RMA
Ah - thanks for the information CB.
