I’ve attempted to uninstall the Media Converter using Add/Remove Programs (XP Pro) and it does get removed from the list, but the start menu item is still there and the program folder remains. The program continues to function as well. Is there some trick to removing it? Now I can’t use Add/Remove to try again, so perhaps there is an app to remove it?
Weirdness.
Go to program files and delete the folder. You can manually delete the shortcuts on your start menu too.
If you REALLY wanted to make sure it’s gone you could install it and try un-installing it, AGAIN, but I’d just probably leave it alone…
