Want to uninstall Cruzer Glide 16 GB on Windows 7. It will not let me. Keeps saying I have to close program. I do close program or so I think I do. HELP please.
Thanks,
Camteddybear
Thanks,
Camteddybear
Thanks,
Camteddybear
Dear Cam,
I have had the same problem. I think it relates to the fact that the Windows7 OS is using the SanDisk to assist in speeding up operations by using a portion of your drive.
I usually have to poke around in the Control Panel part of the Start button on the far lower left of the screen (looks like the MS banner) OS and look for program type information and a properties tab that will allow you to close this feature down (you click or unclick a box).
I think it is an annoyance that SanDisk should fix.
Good luck.
